● 4 NeverDie High Reliability Technology: NFPP, XCor, VSU, XSurge
● Upto 67+ Year MTBF (Mean Time Between Failure)
● Lifetime Free Cloud Management
● Built-in Layer 3 Routing Support
● Power Redundancy Support
RG-S2910-24GT4SFP-UP-H |
24 10/100/1000BASE-T ports (PoE/PoE+) and 4 Gigabit SFP ports (non-combo) uplink, Port 1-4 for HPoE, AC |
RG-S2910-24GT4XS-UP-H |
24 10/100/1000BASE-T ports (PoE/PoE+) and 4 1G/10G SFP+ ports (non-combo) uplink, Port 1-4 for HPoE, AC |
RG-S2910-10GT2SFP-UP-H |
10 10/100/1000BASE-T ports (HPoE/PoE/PoE+) and 2 Gigabit SFP ports (non-combo) uplink, Port 1-8 for HPoE, AC |
Optional Industrial Adapters and Accessories |
Mini-GBIC-SX-MM850 |
1000BASE-SX mini GBIC Transceiver (850nm) |
Mini-GBIC-LX-SM1310 |
1000BASE-LX mini GBIC Transceiver (1310nm) |
Mini-GBIC-LH40-SM1310 |
1000BASE-LH mini GBIC Transceiver (1310nm, 40km) |
Mini-GBIC-ZX50-SM1550 |
1000BASE-ZX mini GBIC Transceiver (1550nm, 50km) |
Mini-GBIC-ZX80-SM1550 |
1000BASE-ZX mini GBIC Transceiver (1550nm, 80km) |
Mini-GBIC-ZX100-SM1550 |
1000BASE-ZX mini GBIC Transceiver (1550nm, 100km) |
10GBASE SFP+ Optical Stack Cable (included both side transceivers) for S2910 and S5750-H Series Switches, 1m |
10GBASE SFP+ Optical Stack Cable (included both side transceivers) for S2910 and S5750-H Series Switches, 3m |
10GBASE SFP+ Optical Stack Cable (included both side transceivers) for S2910 and S5750-H Series Switches, 5m |
Simple Deployment
Shortened construction period
Reduced costs
Secure and Reliable
Easy O&M
Connection of the power supply system to the network for remote restart
Simplified Virtualization Management
On-demand service management and control
Device Security
In tough environments with thunderstorms and electromagnetic interference, devices are prone to damages caused by strong transient currents.
HPoE provides multiple protection mechanisms;
Overcurrent protection, preventing device damages even upon short circuits;
Up to 6KV port lightning protection, ensuring stable operation in various tough environments.
Power Supply Security
In independent deployment mode, strong-current cables are used in most cases. The voltage of power cables is higher than the safe voltage limit (36 V), and may cause accidents.
The HPoE technology complies with international power supply standards and features a low voltage and high safety, ensuring safety of O&M and working personnel.
Network Security
Support for various types of ACL, port security, and IP + MAC + Port binding technologies, effectively preventing various ARP frauds
Proactive prevention against DoS and DDoS attacks
Support for the CPU Protect Policy (CPP) and Network Foundation Protection Policy (NFPP), effectively preventing attacks against standalone devices and the entire network
Stable and Reliable Power Supply
High-power (60 W) and long-distance (100 m) power supply is provided. Compared with the conventional centralized power supply mode:
The HPoE technology complies with international standards; adjusts line loss and lowers voltage intelligently, reducing errors caused by manual adjustment; and provides independent power supply over single ports, achieving faulty domain isolation.
Quick and Easy to Build
No Power Cable Required in Scenarios with Network Cables
To supply electricity to high-power STAs (> 30 W), an independent power supply system needs to be deployed, and the resulted grooving, pipeline layout, wire-threading, debugging, and wall and floor embellishment cause highly complex construction and a long construction period.
Only the network cable is required for power supply and data transmission via HPoE.
Reduced Cost & Less Investment
30% Cost Off in Typical Configuration Mode
If an independent power supply system is deployed, materials such as the power chassis, power cables, power socket, and power adapters are required, while a construction fee will also be incurred, resulting in high overall fees.
In HPoE power supply mode, the previously mentioned materials and accessories are not required, which reduces overall fees by 30% in typical deployment scenarios.
Remote Restart for Easy O&M
In conventional power supply mode, the power supply system is not connected to the network. When a device is faulty, its power supply must be located for a manual restart, which can rapidly resolve most problems. However, if the power supply of the faulty device cannot be restarted due to environmental restrictions, other more complex solutions need to be adopted.
HPoE enables the power supply system to be connected to the network. Consequently, a faulty device can be remotely restarted using a PC to rectify faults rapidly and improve O&M efficiency.
The VSU technology virtualizes multiple physical devices into one logical device and uses a single IP address, Telnet process, and CLI for management.
Multiple devices are managed as one device, ensuring high management efficiency.
On-Demand Service Management and Control
Scheduled power-on/off of STAs:
The STA power-on/off time can be customized based on user habits. -
Uninterrupted power supply during hot start:
Power supply to STAs is not interrupted during restart of the HPoE power supply host. -
Power status check at any time:
Model | RG-S2910-24GT4SFP-UP-H | RG-S2910-24GT4XS-UP-H | RG-S2910-10GT2SFP-UP-H |
Ports | 24 10/100/1000BASE-T ports (PoE/PoE+), 4 Gigabit SFP ports (non-combo) uplink, Port 1-4 for HPoE, AC | 24 10/100/1000BASE-T ports (PoE/PoE+), 4 1G/10G SFP+ ports (non-combo) uplink, Port 1-4 for HPoE, AC | 10 10/100/1000BASE-T ports (8ports PoE/PoE+), 2 Gigabit SFP ports (non-combo) uplink, Port 1-8 for HPoE, AC |
Management Port | 1 console port |
Switching Capacity | Up to 256Gbps | Up to 256Gbps | Up to 256Gbps |
Packet Forwarding Rate | 42Mpps/96Mpps | Up to 96Mpps | Up to 18Mpps |
PoE | IEEE 802.3af, IEEE 802.3at and IEEE 802.3bt |
Port Buffer | 1.5MB |
ARP Table | 1,000 | 1,000 | 500 |
MAC Address | 16K |
Routing Table Size (IPv4/IPv6) | 500 (IPv4/IPv6) | 500 (IPv4/IPv6) | 64 (IPv4/IPv6) |
ACL Entries | In: 1500 | In: 1500 | In: 750 |
VLAN | Port-based VLAN, MAC-based VLAN, Protocol-based VLAN, Private VLAN, Voice VLAN, IP subnet-based VLAN, GVRP |
QinQ | Basic QinQ, Flexible QinQ |
Port Mirroring | Support aggregation port as source and destination port of mirroring; Flow-based mirroring; VLAN-based mirroring; Many-to-one mirroring; One-to-many mirroring; Cross-device traffic mirroring; RSPAN; ERSPAN | Support aggregation port as source and destination port of mirroring; Flow-based mirroring; VLAN-based mirroring; Many-to-one mirroring; One-to-many mirroring; Cross-device traffic mirroring; RSPAN; ERSPAN | Support aggregation port as source and destination port of mirroring; Flow-based mirroring; VLAN-based mirroring; Many-to-one mirroring; One-to-many mirroring; RSPAN; ERSPAN |
Spanning Tree Protocols | IEEE802.1d STP, IEEE802.1w RSTP, standard 802.1s MSTP, Port fast, BPDU filter, BPDU guard, TC guard, TC protection, ROOT guard |
DHCP | DHCP server, DHCP client, DHCP snooping, DHCP relay, IPv6 DHCP snooping, IPv6 DHCP client, IPv6 DHCP relay |
Multiple Spanning Tree Protocol (MSTP) Instances | 64 |
SDN | OpenFlow |
VSU | VSU Stack Members | Up to 9 stack members | N/A |
VSL | 4 BASE-X ports can be configured as VSL | N/A |
Zero Configuration | CWMP(TR069) |
L2 Features | MAC, VLAN, Basic QinQ, Felix QinQ, Mirroring, STP, RSTP, MSTP, Broadcast storm control, IGMP v1/v2/v3 snooping, IGMP filter, IGMP fast leave, Jumbo frame, RLDP, LLDP, REUP, G.8032 |
Layer 2 Protocols | IEEE802.1d, IEEE802.1w, IEEE802.1s, IGMP Snooping v1/v2/v3 |
Layer 3 Features | ARP, IPv4/v6 |
IPv4 Features | Ping, Traceroute |
IPv6 Features | 0-64 any length mask, ICMPv6, Neighbor Discovery, Manually configure local address, Automatically create local address, IPv6 Ping, IPv6 Tracert, IPv6 extender option head |
Basic IPv6 Protocols | IPv6 addressing, Neighbor Discovery (ND), IPv6 ACL, ICMPv6, IPv6 Ping, IPv6 Tracert |
IPv4 Routing Protocols | Static Routing, RIP, OSPFv1/v2 |
IPv6 Routing Protocols | Static Routing, RIPng, OSPFv3 |
G.8032 | Support |
ACL | Standard IP ACL, Extended IP ACL, Extended MAC ACL, Expert ACL, ACL80, IPv6 ACL, ACL Logging, ACL Counter, ACL Remark, Global ACL, ACL Redirect |
QoS | 802.1p/DSCP traffic classification; Multiple queue scheduling mechanisms, such as SP, WRR, DRR, SP+WRR, SP+DRR; Input / output port-based speed limit; Each port supports 8 queue priorities,Dynamic QoS | 802.1p/DSCP traffic classification; Multiple queue scheduling mechanisms, such as SP, WRR, DRR, SP+WRR, SP+DRR; Input / output port-based speed limit; Each port supports 8 queue priorities,Dynamic QoS | 802.1p/DSCP traffic classification; Multiple queue scheduling mechanisms, such as SP, WRR, DRR, SP+WRR, SP+DRR; Input port-based speed limit; Each port supports 8 queue priorities,Dynamic QoS |
Reliability | GR for RIP | GR for RIP | GR for RIP |
EEE Format | Support IEEE 802.3az standard |
Security | Binding of the IPv6 and MAC address; Port-based and MAC-based 802.1x; MAB; Portal and Portal 2.0 authentication; ARP-check; DAI; Gateway anti-ARP spoofing; Hierarchical management by administrators and password protection; RADIUS and TACACS+; SSH V1.5 and SSH V2.0; IP source guard; CPP, NFPP; Port protection |
Manageability | SNMPv1/v2c/v3, RMON(1, 2, 3, 9), SSH, Syslog / Debug, NTP / SNTP, FTP, TFTP, Web |
Smart Temperature Control | Temperature monitoring and alert |
Dimensions (W x D x H) (mm) | 440×260×44 | 440×260×44 | 340×260×44 |
Rack Height | 1RU |
MTBF | 361712 hours | 388055 hours | 408710 hours |
Lightning Protection on Power Port | 6 Common Mode 4KV/Differential Mode 2K | Common Mode 4KV/Differential Mode 2K | Common Mode 6KV/Differential Mode 6KV |
Lightening Protection on Communication Port | Common Mode 6KV |
Power Supply | AC input: |
Power Consumption | <460W | <460W | <630W |
PoE Power Consumption | Total 370W PoE/PoE+/HPoE budget output power | Total 370W PoE/PoE+/HPoE budget output power All 24 BASE-T ports support PoE (up to 24 ports) and PoE+ (up to 12 ports) All ports from Port 1-4 support HPoE output power of up to 60W per port | Total 520W PoE/PoE+/HPoE budget output power All ports from Port 1-8 support HPoE output power of up to 60W per port |
Temperature | Operating temperature: 0°C to 50°C |
Storage temperature: -40°C to 70°C |
Humidity | Operating humidity: 10% to 90%RH |
Storage humidity: 5% to 95%RH |
Operating Altitude | -500m to 5,000m |
- Hardware Installation Guide
- Ruijie Transceiver Installation and Reference Guide, V2.6 2017-07-19
- RG-S2910-H Series Switch Hardware Installation and Reference Guide V1.1 2016-08-01
- Ruijie Transceiver Installation and Reference Guide 2017-07-19
- RG-PBOX Series Power Adapter Hardware Installation and Reference Guide,V1.01 2017-08-07
- RG-PBOX Series Power Adapter Hardware Installation and Reference Guide,V1.01 2016-08-08
- Ruijie RG-S2910-H Series Switches Hardware Installation and Reference Guide V1.28 2019-09-23
- Ruijie Transceiver Installation and Reference Guide, V3.0 2020-06-30
- Ruijie RG-PBOX Series Power Adapters Hardware Installation and Reference Guide,V1.01 2017-08-07
- Product Datasheet
- RG-S2910-H HPoE Switch Series Datasheet 2020-11-16
- Brochure
- RGOS Configuration Guide
- Ruijie RG-S29 Series Switches RGOS Configuration Guide, Release 11.4(1)B70P1 2019-12-03
- RG-S2910-H Series Switch RGOS Configuration Guide,Release 11.4(1)B1P2-IP Routing Configuration 2017-06-18
- RG-S29 Series Switch RGOS Configuration Guide, Release 11.4(1)B12_Reliability Configuration 2018-06-27
- RG-S29 Series Switch RGOS Configuration Guide, Release 11.4(1)B12 2017-09-18
- RG-S29 Series Switch RGOS Configuration Guide, Release 11.4(1)B12_Specifications and Limitations 2018-06-27
- RG-S29 Series Switch RGOS Configuration Guide,Release 11.4(1)B12_IP Routing Configuration 2018-06-27
- RG-S29 Series Switch RGOS Configuration Guide,Release 11.4(1)B12_System Configuration 2018-06-27
- RG-S29 Series Switch RGOS Configuration Guide, Release 11.4(1)B12_Security Configuration 2017-09-06
- RG-S29 Series Switch RGOS Configuration Guide, Release 11.4(1)B12_Network Management Configuration 2018-06-27
- RG-S29 Series Switch RGOS Configuration Guide, Release 11.4(1)B12_Multicast Configuration 2017-09-06
- RG-S29 Series Switch RGOS Configuration Guide, Release 11.4(1)B12_IP Address Configuration 2018-06-27
- RG-S29 Series Switch RGOS Configuration Guide, Release 11.4(1)B12_Ethernet Configuration 2018-06-27
- RG-S29 Series Switch RGOS Configuration Guide, Release 11.4(1)B12_ACL&QoS Configuration 2017-09-04
- RG-S2910-H Series Switch RGOS Configuration Guide,Release 11.4(1)B1P2-Ethernet Configuration 2017-06-18
- RG-Switch RGOS Web-Based Configuration Guide, Release 11.4(1)B2 2016-03-09
- Ruijie RG-Switch RGOS Web-Based Configuration Guide 2017-08-31
- RG-Switch RGOS Web-Based Configuration Guide 2017-06-13
- RG-S2910-H Series Switch RGOS Configuration Guide,Release 11.4(1)B1P2-Network Management Configuration 2017-06-18
- RG-S2910-H Series Switch RGOS Configuration Guide,Release 11.4(1)B1P2- IP Address Configuration 2017-06-18
- Ruijie RG-S29 Series Switches RGOS Configuration Guide, Release 11.4(1)B42P1 2019-03-11
- RG-S2910H Series Switch RGOS Configuration Guide,Release 11.4(1)B1P2 2017-01-09
- RG-S2910-H Series Switch RGOS Configuration Guide,Release 11.4(1)B1P2--ACL&QoS Configuration 2017-06-18
- RG-S2910H Series Switch RGOS Configuration Guide,Release 11.4(1)B3 2016-08-01
- RG-S2910-H Series Switch RGOS Configuration Guide,Release 11.4(1)B1P2-Specifications and Limitations 2017-06-18
- RG-S2910-H Series Switch RGOS Configuration Guide,Release 11.4(1)B1P2-System Configuration 2017-06-18
- RG-S2910-10GT2SFP-UP-H Series Switch RGOS Configuration Guide,Release 11.4(1)B17 2017-04-12
- RG-S2910-H Series Switch RGOS Configuration Guide,Release 11.4(1)B1P2-Multicast 2017-06-18
- RG-S2910-H Series Switch RGOS Configuration Guide,Release 11.4(1)B1P2-Security Configuration 2017-06-18
- RG-S2910-H Series Switch RGOS Configuration Guide,Release 11.4(1)B1P2-Reliability Configuration 2017-06-18
- RGOS Command Reference
- Ruijie RG-S29 Series Switches RGOS Command Reference, Release 11.4(1)B70P1 2019-12-03
- RG-S2910-H Series Switch RGOS Command Reference 11.4(1)B1P2-IP Address Config 2017-06-18
- RG-S2910-H Series Switch RGOS Command Reference 11.4(1)B1P2-Ethernet Config 2017-06-18
- RG-S2910-H Series Switch RGOS Command Reference 11.4(1)B1P2-System Configration 2017-06-18
- RG-S2910-H Series Switch RGOS Command Reference 11.4(1)B1P2-ACL&QoS 2017-06-18
- RG-S2910-H Series Switch RGOS Command Reference 11.4(1)B1P2-Security 2017-06-18
- RG-S2910H Series Switch RGOS Command Reference,Release 11.4(1)B1P2 2017-01-09
- RG-S29 Series Switch RGOS Command Reference,Release 11.4(1)B12_Ethernet Configuration Commands 2017-09-18
- RG-S2910-H Series Switch RGOS Command Reference 11.4(1)B1P2-IP Routing 2017-06-18
- RG-S29 Series Switch RGOS Command Reference,Release 11.4(1)B12 2018-06-28
- RG-S2910H Series Switch RGOS Command Reference,Release 11.4(1)B3 2016-08-01
- RG-S2910-H Series Switch RGOS Command Reference 11.4(1)B1P2-Network Management 2017-06-18
- RG-S2910-10GT2SFP-UP-H Series Switch RGOS Command Reference,Release 11.4(1)B17 2017-04-12
- RG-S2910-H Series Switch RGOS Command Reference 11.4(1)B1P2-Reliability 2017-06-18
- RG-S2910-H Series Switch RGOS Command Reference 11.4(1)B1P2-Multicast 2017-06-18
- Ruijie RG-S29 Series Switches RGOS Command Reference,Release 11.4(1)B42P1 2019-03-11
- White Paper
- Test Report
- tolly test report for s2910 of ruijie 2017-03-27
- Software Download
- RG-S2910-H_RGOS11.4(1)B12P11_install Firmware 2019-12-22
- RG-S2910-H_RGOS11.4(1)B42P1_05172823_install Firmware 2019-12-22
- Ruijie RG-S2910-H Series Switch RGOS11.4(1)B70P1 Firmware 2020-02-14
- RG-S2910-H_RGOS11.4(1)B1P2_install Firmware 2016-12-18
- 待补录数据:RG-S2910-H_RGOS11.4(1)B12P11_install Firmware 2017-12-22
- RG-S2910-10UP_RGOS11.4(1)B12P24_install Firmware 2019-07-08
- RG-S2910-10P_RGOS11.4(1)B12P24_install Firmware 2019-07-08
- RG-S2910-H_RGOS11.4(1)B12P24_install Firmware 2019-07-08
- 待补录数据:RG-S2910-H_RGOS11.4(1)B12P11_install Firmware 2018-01-02
- PoC Guide
- Ruijie Switch PoC Guide (V1.2) 2020-02-14
- Presentation
- Ruijie 3-In-1 Campus Solution Overview 2017-08-16
- NEW Option for Remote High Power Supply 2017-07-17
- SCN+ Higher Education Solution
- Ruijie Product Catalogue Brochure 20190418 2019-04-17
- Ruijie Switch 17 Years 2017-08-10
