RG-S6510-48VS8CQ |
RG-S6520-64CQ |
Ports |
48 fixed 25G SFP28 ports 8 100G QSFP28 ports |
64 fixed 100G QSFP28 ports |
Modular Power Slots |
2 |
2 |
Fan Slots |
4 |
3 |
Management Ports |
1 console port 1 MGMT port 1 USB 2.0 port |
Switching Capacity |
4.0Tbps |
12.8Tbps |
Packet Forwarding Rate |
2000Mpps |
4400Mpps |
Port Buffer |
32MB |
42MB |
RAM |
4GB |
4GB |
ARP Table |
Up to 100K |
Up to 90K |
MAC Address |
Up to 96K |
Up to 72K |
Up to 28K |
Multicast Entries (IPv4/IPv6) |
Up to 16K |
Up to 8K |
ACL Entries |
Up to 4.5K |
Up to 1.5K |
VLAN |
4K VLANs, Port-based VLAN, MAC-based VLAN, Super VLAN, Protocol-based VLAN, Private VLAN, IP subnet-based VLAN, GVRP |
QinQ |
Basic QinQ, Flexible QinQ |
Link Aggregation |
Support LACP |
Port Mirroring |
Many-to-one mirroring, One-to-many mirroring, Flow-based mirroring, Over devices mirroring, VLAN-based mirroring, VLAN-filtering mirroring, AP-port mirroring, RSPAN, ERSPAN |
Spanning Tree Protocols |
IEEE802.1d STP, IEEE802.1w RSTP, Standard 802.1s MSTP, Port fast, BPDU filter, BPDU guard, TC guard, TC protection, Loop guard, Root guard,Spanning Tree Root Guard(STRG) |
DHCP |
DHCP server, DHCP client, DHCP snooping, DHCP relay, IPv6 DHCP relay |
Multiple Spanning Tree Protocol (MSTP) Instances |
64 (not include default 0) |
Up to 256 |
Virtual Routing and Forwarding (VRF) Instances |
Up to 2K |
Up to 1K |
Data Center Unified Network Features |
Virtualization: Virtual Switch Unit (VSU), EVPN VXLAN, Open-Flow. Visualization: INT, gRPC, s-FLOW, Others: PFC, ECN |
Virtualization: Virtual Switch Unit (VSU), Open-Flow. Visualization: INT, gRPC, s-FLOW, Others: PFC, ECN |
VSU (Virtual Switch Unit) |
Support (up to 2 stack members) |
L2 Features |
MAC, ARP, VLAN, Basic QinQ, Felix QinQ, Link aggregation, Mirroring, STP, RSTP, MSTP, Broadcast storm control, IGMP v1/v2/v3 snooping, IGMP filter, IGMP fast leave, MLD snooping, DHCP, Jumbo frame, RLDP, LLDP |
Layer 2 Protocols |
IEEE802.3 (10BASE-T), IEEE802.3u (100BASE-T), IEEE802.3z (1000BASE-X), IEEE802.3ab (1000BASE-T), IEEE802.3ae (10GBASE-T), IEEE802.3an (10GBASE-T), IEEE802.3ak, IEEE802.3an, IEEE802.3x, IEEE802.3ad (link aggregation), IEEE802.1p, IEEE802.1x, IEEE802.1Q, IEEE802.1D (STP), IEEE802.1w (RSTP), IEEE802.1s (MSTP), IGMP snooping, Jumbo Frame (9Kbytes), IEEE802.1ad (QinQ and flexible QinQ), GVRP |
Layer 3 Features |
ARP, IPv4/v6, PBRv4/v6 |
Layer 3 Protocols (IPv4) |
BGP4, OSPFv2, RIPv1, RIPv2, MBGP, LPM routing, Policy-based routing, Route-policy, ECMP, WCMP, VRRP, IGMP v1/v2/v3, DVMRP, PIM-SSM/SM/DM, MSDP, Any-RP, ISIS |
IPv4 Features |
Ping, Traceroute, Equal-cost routing, URPF, IPIP, GRE tunnel, VRF |
IPv6 Features |
Static routing Equal-cost routing, Policy-based routing, OSPFv3, RIPng, BGP4+, MLDv1/v2, PIM-SMv6, Manual tunnel, Auto tunnel, IPv4 over IPv6 tunnel, ISATAP tunnel |
Basic IPv6 Protocols |
ND, ICMPv6, Path MTU Discovery, DNSv6, DHCPv6, ICMPv6, ICMPv6 redirection, ACLv6, TCP/UDP for IPv6, SNMP v6, Ping /Traceroute v6, IPv6 RADIUS, Telnet/SSH v6, FTP/TFTP v6, NTP v6, VRRP for IPv6, IS-ISv6 |
IPv6 Routing Protocols |
Static routing, Equal-cost routing, Policy routing, RIPng, OSPFv2/v3, BGP4+, IS-IS |
IPv6 Tunnel Features |
Manual tunnel, Auto tunnel, 6over4 manual tunnel, 6to4 auto tunnel, ISATAP, IPv4 over IPv6 tunnel, IPv6 over IPv6 tunnel, GRE tunnel |
IGMP v1/v2/v3, IGMP proxy, MSDP, PIM-DMv4 (PIM-DM), PIM-SMv4 (PIM-SM, PIM-SSM), PIM-SM v6, MLD, MLD Proxy |
ACL |
Standard/Extended/Expert ACL, Extended MAC ACL, ACL 80, IPv6 ACL |
QoS |
EXP priority mapping based on 802.1p, DSCP, TOS and IP Precedence; ACL traffic classification; Priority marking/remarking; Multiple queue scheduling mechanisms, such as SP, WRR, DRR, SP+WRR, and SP+DRR |
VSU (virtualization technology for virtualizing multiple devices into 1); GR for OSPF/IS-IS/BGP; BFD detection; REUP dual-link fast switching technology; RLDP (Rapid Link Detection Protocol); 1+1 power redundancy; 2+1 fan redundancy; Hot-swappable line cards and power modules, Dynamic ARP Inspection(DAI),de-stacking |
VSU (virtualization technology for virtualizing multiple devices into 1); GR for OSPF/IS-IS/BGP; BFD detection; REUP dual-link fast switching technology; RLDP (Rapid Link Detection Protocol); 1+1 power redundancy; 2+1 fan redundancy; Hot-swappable line cards and power modules, Dynamic ARP Inspection(DAI), |
Network Foundation Protection Policy (NFPP); CPU Protection (CPP); DoS protection; Detection of unauthorized data packets; Data encryption; IP source guard; RADIUS / TACACS+; IPv4 / IPv6 ACL packet filtering based on standard or extended VLANs; Plaintext authentication and MD5 cipher-text authentication of OSPF, RIPv2, and BGPv4 packets; Telnet login through limited IP addresses and the password mechanism; u-RPF; Broadcast packet suppression; DHCP snooping, DHCP Option 82,; Anti-gateway ARP spoofing; ARP check, |
Manageability |
SNMP v1/v2c/v3; Telnet; Console; Hardware support RCMI (combo interface for MGMT); RMON; SSHv1/v2; FTP/TFTP for file upload and download management; NTP clock; Syslog; SPAN/RSPAN, |
Hot Patch |
Support |
Smart Temperature Control |
Auto fan speed adjustment; Fan malfunction alerts; Fan status check |
Smart Power Supply |
Support power monitor |
Other Protocols |
DHCP client, DHCP relay, DHCP server, DNS client, UDP relay, ARP proxy, Syslog |
Dimensions (W x D x H) (mm) |
442 * 387 * 44 |
442 * 450 * 88.1 |
Rack Height |
1RU |
2RU |
8kg (incl. 4 fan modules and 2 power supply modules) |
14.8kg (incl. 3 fan modules and 2 power supply modules) |
330K hours |
>200K hours |
Safety Standards |
EN 60950-1, GB4943-2011 |
Emission Standards |
GB9254-2008 CLASSA, VCCI Class A, EN 300 386, EN 55032, EN 61000-3-2, EN 61000-3-3, EN 55035, EN 61000-4-2, EN 61000-4-3, EN 61000-4-4, EN 61000-4-5, EN 61000-4-6, EN 61000-4-8, EN 61000-4-11 |
Power Supply |
AC input: Rated voltage range: 100V to 240V AC Frequency: 50-60Hz Rated current: 7.2A-3.5A HVDC input: Input voltage range: 192V to 288V DC Input current range: 3.6A |
AC input: Rated voltage range: 100V to 240V AC Frequency: 50-60Hz Rated current:10A-5A HVDC input: Input voltage range: 192V to 288V DC Input current range:4.5A |
Power Consumption |
<300W |
<600W |
Temperature |
Operating temperature: 0°C to 45°C Storage temperature: -40ºC to 70ºC |
Humidity |
Operating humidity: 10% to 90%RH |
Operating Altitude |
-500—5000 M |
