Applications
Switching capacity: 68 Gbps
Forwarding rate: 51 Mpps
Local & Cloud O&M
Visualized Management
Alarm Processing
Tài liệu
RG-S5000-10GT2MS-E
RG-S5000-10GT2MS-P-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
2 x 2.5GE/1GE SFP ports
PoE/PoE+ supported
24 x
4 x 2.5G/1GE SFP ports
4 x 2.5GE/1GE SFP ports
PoE/PoE+ supported
1 x fixed module
1 x fixed module
2 x fixed modules
2 x fixed modules
30 Gbps
30 Gbps
68 Gbps
68 Gbps
116 Gbps
256
Weight (full load)
2 kg (4.41 lbs)
2.5 kg (5.51 lbs)
2.5 kg (5.51 lbs)
2.8 kg (6.17 lbs)
2.8 kg (6.17 lbs)
ARM Cortex A9, 1.2 GHz
64 MB flash memory
16 W
141 W (PoE power: 125 W)
430 W (PoE power: 370 W)
> 200K
> 200K
> 200K
> 200K
> 200K
40 dB
40 dB
40 dB
Common mode 10 kV
Common mode 10 kV
Common mode 10 kV
Common mode 10 kV
Common mode 10 kV
Others
Installation mode
RG-S5000-E Series
Port-based VLAN assignment
Basic QinQ and selective QinQ
DNS client
Neighbor Discovery (ND)
Expert ACLs
Port rate limiting
IEEE 802.1X authentication
Proxy ARP and ARP entry aging
Hardware CPP and NFPP
Load balancing modes
TFTP (TFTP client)
SSH v1.5/v2.0
l IEEE 802.3af and 802.3at
l Port priority
Cloud
WIS
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
