RG-CS86-20XS4VS2QXS-D Thiết bị chuyển mạch - 1
RG-CS86-20XS4VS2QXS-D Thiết bị chuyển mạch - 2
RG-CS86-20XS4VS2QXS-D Thiết bị chuyển mạch - 3
RG-CS86-20XS4VS2QXS-D Thiết bị chuyển mạch - 4
RG-CS86-20XS4VS2QXS-D Thiết bị chuyển mạch - 5
RG-CS86-20XS4VS2QXS-D Thiết bị chuyển mạch - 6
RG-CS86-20XS4VS2QXS-D Thiết bị chuyển mạch - 7
RG-CS86-20XS4VS2QXS-D Thiết bị chuyển mạch - 8
RG-CS86-20XS4VS2QXS-D Thiết bị chuyển mạch - 9
RG-CS86-20XS4VS2QXS-D Thiết bị chuyển mạch - 10
and Network Connectivity
4 x 10GE/25GE SFP28 ports
Note: One switch provides a maximum of 32 x 10GE ports.
2 x fan power module slots
Fan module
M1SFAN I-F (pre-installed 2)
570 Mpps
760 Gbps
32,768
In: 2,500
Out: 1,000
440 mm x 330 mm x 43.6 mm (17.32 in. x 12.99 in. x 1.72 in.)
545 mm x 500 mm x 232 mm (21.46 in. x 19.69 in. x 9.13 in.)
4.6 kg (10.14 lbs) (empty chassis with 2 fan modules)
6.40 kg (14.11 lbs) (empty chassis with 2 fan modules)
RG-PA150I-F (AC input):
● Rated input voltage: 100 V AC to 240 V AC, 50 Hz to 60 Hz
RG-PA150I-F: 150 W
85 W
2 x pluggable fan modules
≤ 78 dB
Temperature alarming
Super VLAN, private VLAN
Telnet
Switch and Power Module
20 x 1GE/2.5GE/10GE SFP+ ports, 4 x 10GE/25GE SFP28 ports, 2 x 40GE QSFP+ ports, supporting up to 32 x 10GE ports
2 x slots for power supply modules, requiring at least one RG-PA150I-F power module
2 x slots for fan modules, 2 x pre-installed fans (Purchase at least one RG-PA150I-F module.)
150 W AC power module
  • 20 x 1GE/2.5GE/10GE SFP+ ports support 1GE SFP transceivers, 2.5GE SFP transceiversand 10GE SFP+ transceivers.
25GE
40GBASE, QSFP+ active optical cable (AOC), 10 m, including one cable and two optical transceivers
