RG-S2910-24GT4SFP-UP-H, 24-Port Gigabit L2+ Managed POE Switch
Network Security
RG-S2910-24GT4XS-UP-H
System
56 Gbps
42 Mpps
Input voltage
PoE power supply
10% to 90% RH
5% to 95% RH
4K VLANs
IP subnet-based VLAN
Standard IP ACL
Extended IP ACL
Time range-based ACL
Global ACL
IPv6 DHCP snooping
IPv6 DHCP client
IPv6 DHCP relay
Layer 2 protocols
Invalid MAC address filtering
Trusted ARP
SSH and SSHv2.0
Cable diagnostics
Cable detection
Port sleeping
Port sleeping
Interface priority
IPv4/ IPv6 static route
Routing policy
IPv6
Basic protocols
VSU features
Zero Touch Provisioning (ZTP)
Management features
●  Purchase the chassis.
