RG-CS88-08 Ruijie Cloud Managed 10 RU Modular High-Performance Core Switch
Dual-Boot Backup
1+1 Supervisor
Module Redundancy
1+1 Supervisor
Module Redundancy
N+M Power Supply Redundancy
1+1 Fan Redundancy
1+1 Fan Redundancy
Tài liệu
RG-CS88-08
Supervisor module slots
Line card slot
Switch fabric module slot
9.6 Tbps
7200 Mpps
EB card: 64,000
FA card: 80,000
FB card: 96,000
EB card: 4,000
DA card: 10,000
FA card: 4,000
FB card: 40,000
EB card: 8,000
DA card: 16,000
FA card: 8,000
FB card: 16,000
EB card: 4,000
DA card: 8,000
FA card: 4,000
FB card: 8,000
● Ingress
EB card: 3,500
DA card: 8,000
FA card: 5,000
FB card: 4,500
● Egress
EB card: 1,000
DA card: 1,000
FA card: 1,000
FB card: 2,000
35.6 kg (78.48 lbs)
● Supervisor module
M7800C-CM: 1.0 GHz quad-core processor
● Service module
● Flash memory
Supervisor module:
M7800C-CM/M7808C-CM II: 8 GB
Service module:
EA card: 512 MB
EB card: 512 MB
DA/F card: 8 GB
● SDRAM
Supervisor module:
M7800C-CM: DDR3 4 GB
M7808C-CM II: DDR4 4 GB
Service module:
EB card: DDR3 1 GB
DA card: DDR4 1 GB
F card: DDR4 2 GB
● Chassis
RG-S7808C: < 176 W
● Supervisor module:
M7808C-CM II: < 50 W
● Service module:
M7800C-36GT12SFP4XS-EB: < 80 W
M7800C-48GT4XS-EB: < 70 W
M7800C-48SFP4XS-EB: < 101 W
M7800C-32XS4QXS-DA: < 210 W
M7800C-24XT4QXS-DA: < 245 W
M7800C-48GT-FA: < 75 W
M7800C-48SFP-FA: < 95 W
M7800C-48XS-FB: < 160 W
M7800C-4CQ-FB: < 120 W
M7800C-8CQ-FB: < 130 W
● RG-PA600I-F: 600 W
● RG-PA1600I-F: 90 V AC to 180 V AC
power: 1,600 W
Right-to-rear airflow
● System power module
RG-CS88 Series
MPLS IPv6
MPLS 6VPE
DHCPv6 client, DHCPv6 relay, and DHCPv6 snooping
OSPFv2 and OSPFv3
IPv4/IPv6 IS-IS
Policy-based routing (PBR)
EVPN
IGMP snooping v1/v2/v3
MLD v1/v2 snooping
802.1p
CAR
VRRP for the super-VLAN
RG-CS88-08
CM88-CM
2.Power Modules and Fans
RG-PA600I-F
RG-PA1600I-F
M08-FAN
3.Line Cards
Commercial-grade line cards
CM88-48XS-H
CM88-8CQ-H
CM88-48GT-H
CM88-48SFP-H
