RG-CS86-24MG4VS-UP Thiết bị chuyển mạch - 1
RG-CS86-24MG4VS-UP Thiết bị chuyển mạch - 2
RG-CS86-24MG4VS-UP Thiết bị chuyển mạch - 3
RG-CS86-24MG4VS-UP Thiết bị chuyển mạch - 4
RG-CS86-24MG4VS-UP Thiết bị chuyển mạch - 5
RG-CS86-24MG4VS-UP Thiết bị chuyển mạch - 6
RG-CS86-24MG4VS-UP Thiết bị chuyển mạch - 7
RG-CS86-24MG4VS-UP Thiết bị chuyển mạch - 8
RG-CS86-24MG4VS-UP Thiết bị chuyển mạch - 9
RG-CS86-24MG4VS-UP Thiết bị chuyển mạch - 10
RG-CS86-24MG4VS-UP Thiết bị chuyển mạch - 11
RG-CS86-24MG4VS-UP 24-Port Multi-GE Switch with Cloud Management, Full 1GE/2.5GE/5GE Access with PoE++
  • 24 x 100/1000/2.5G/5GBASE-T ports for access, 4 x 10GE/25GE ports for uplink, meeting high-bandwidth campus network demands
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
RG-CS86-24XMG4XS4VS-UPD
RG-CS86-48MG4VS2QXS-UPD
4 x 10GE/25GE SFP28 ports
● Ports 1 to 24 support PoE++
2 x 40GE QSFP+ ports
M2SFAN I-F (pre-installed 3)
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
327 Mpps
327 Mpps
565 Mpps
625 Mpps
440 Gbps
440 Gbps
760 Gbps
840 Gbps
Dual-core CPU, each core with the clock speed of 1.25 GHz
Switch buffer
32,768
Egress:1,000
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
568 mm x 366 mm x 226 mm
563 mm x 563 mm x 210mm
3.65 kg (8.82 lbs)
6.11 kg (13.47 lbs)
5.37 kg (11.84 lbs)
8.12 kg (17.90 lbs)
8.42 kg (18.56 lbs)
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
90 W (without PoE)
120 W (without PoE)
1,650 W (full PoE load)
240 W (without PoE)
1,600 W (full PoE load)
Each PoE port provides up to 90 W of power
● RG-PA600I-P-F: PoE 370W (740 W with dual power supplies)
● RG-PA1000I-P-F: PoE 740W (1480 W with dual power supplies)
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
Temperature alarming
Service port: 4 kV
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
GR for RIP, OSPF, BGP
RG-CS86-24MG4VS-UP
fixed AC power supply and fan
RG-CS86-12XMG4VS-UP
25GE
VG-SFP-AOC7M
