RG-SF2920-8GT2MG2XS Thiết bị chuyển mạch - 1
RG-SF2920-8GT2MG2XS Thiết bị chuyển mạch - 2
RG-SF2920-8GT2MG2XS Thiết bị chuyển mạch - 3
RG-SF2920-8GT2MG2XS Thiết bị chuyển mạch - 4
RG-SF2920-8GT2MG2XS Thiết bị chuyển mạch - 5
RG-SF2920-8GT2MG2XS Thiết bị chuyển mạch - 6
1 x 1GE/2.5GE SFP port
16 x 10/100/1000BASE-T ports
2 x 1GE SFP ports
2 x 1GE SFP ports
System switching capacity *2
1 MB
256 MB
512 MB DDR3
1.5 MB
56.5 Mpps
76 Gbps
256 MB
512 MB DDR3
1.5 MB
1.18 kg (2.6 lbs)
1.43 kg (3.15 lbs)
1.74 kg (3.84 lbs)
1.97 kg (4.34 lbs)
2.04 kg (4.5 lbs)
2.81 kg (6.19 lbs)
2.34 kg (5.16 lbs)
2.33 kg (5.14 lbs)
2.33 kg (5.14 lbs)
Fixed power supply: 70 W
Fixed power supply: 150 W
The maximum power is 45 W
8.5 W
10 W (without PoE load)
55 W (full PoE load)
16.5 W (without PoE load)
141.5 W (full PoE load)
25 W (without PoE load)
150 W (full PoE load)
RG-SF2920 Series
Air discharge: 15 kV
Contact discharge: 8 kV
RG-SF2920 Series
RG-SF2920U
RG-SF2920
CWDM
XG-SFP-LR(A1-4)-H
XG-SFP-LR(A1-8)-H
GE-SFP-LR(A1-4)-H
GE-SFP-LR(A1-8)-H
