Home> Sản phẩm> Thiết bị chuyển mạch> Core/Aggregation Switches>
RG-N18000 Series Switches
Xem thêm+
Cloud Network-oriented
New-Generation Core Switch
TOLLY Group
Advanced CLOS Architecture
Virtual Switch Unit 3.0 (VSU)
Virtual Switch Device (VSD)
Core Concepts
Solution Components
●Hardware Switching Devices:
●SDN Controller RG-IONC
○MPLS L3 VPN service
RG-N18007
RG-N18010
RG-N18012
RG-N18014
Module Slots
7 (2 for control engines)
10(2 for control engines)
12(2 for control engines)
14 (2 for control engines)
Modular Power Slots
6 (all for system power)
8 (all for system power)
Fan Slots
Control Engine Slots
Service Module Slots
12
Fabric Engine Slots
50Tbps/208.5Tbps
80Tbps/333.6Tbps
100Tbps/417Tbps
120Tbps/500.4Tbps
900Mpps
11,520Mpps
3,840Mpps
17,280Mpps
Max. Number of 10GE Ports
Up to 240
Up to 768
Up to 480
Up to 1,152
Max. Number of 40GE Ports
Up to 60
Up to 192
Up to 120
Up to 288
Max. Number of 100GE Ports
Up to 96
Up to 120
Up to 144
Up to 16MB
Up to 24GB
Up to 24MB
Up to 24GB
Up to 170K
Up to 512K
Up to 512K
Up to 225K
Up to 512K
Routing Entries
Up to 384K
Routing Table Size
(IPv4/IPv6)
Up to 12K/6K
Up to 384K/128K
Up to 384K/128K
Up to 384K/128K
Multicast Entries
(IPv4/IPv6)
Up to 16K/8K
Up to 8K
4K
Basic QinQ, Flexible QinQ
AP, LACP
STP, RSTP and MSTP
64 (not include default 0)
Up to 256
Up to 2K
L2 GRE
OpenFlow
Up to 2 stack members
VSD (Virtual Switch Device)
Up to 12 VSD units
Layer 3 Features
ARP, IPv4/v6, PBR v4/v6
Layer 3 Protocols (IPv4)
IPv6 Tunnel Features
ACE Capacity
Up to 8K
Support EEE (802.3az)
Hot Patch
Smart Power Supply
(W x D x H) (mm)
442 x 598 x 352.8
442 x 836 x 797.3
442 x 725 x 708.4
442 x 814 x 886.2
8RU
18RU
16U
20RU
30.2kg
103.32kg
107.55kg
229K hours
259K hours
259K hours
216K hours
180-264V~1600W (PoE)
210-264V~3000W (PoE)
<432W
<730W
<518W
<860W
PoE Power
<6,000W
<6,000W
-500m to 4,000m
Weight and Typical Power
Component
Maximum Power
Main Chassis
30.2kg
432W
103.32kg
730W
105kg
518W
107.55kg
860W
Control Engine
1.68 kg
40W
  • M18007-CM II
2.0kg
102W
  • M18007-CM II Lite
2.0kg
102W
  • M18010-CM
1.68kg
40W
  • M18010-CM II
2.04kg
95W
  • M18012-CM
1.68kg
40W
  • M18012-CM II
2.0kg
95W
  • M18014-CM
3.22kg
40W
  • M18014-CM II
3.58kg
100W
Fabric Engine
  • M18010-FE-C I
2.72kg
90W
  • M18010-FE-D I
2.8kg
107W
  • M18010-FE-D III
3.36kg
313W
  • M18012-FE-D I
2.2kg
107W
  • M18014-FE-D I
3.76kg
158W
  • M18014-FE-D III
4.56kg
425W
  • RG-PA1600I
2.04kg
  • RG-PA600I
1.64kg
  • RG-PA1600I-P
1.6kg
1.6kg
  • RG-PA3000I-PL
1.6kg
  • RG-PD1600I
1.6kg
  • RG-PD600I
1.3kg
Line Card & Service Module
  • M18000-44SFP4XS-ED
3.76kg
135W
  • M18000-44SFP4XS-EF
3.86kg
175W
  • M18000-44SFP4XS-CB
5.06kg
267W
  • M18000-48GT-ED
3.7kg
95W
  • M18000-48GT-EF
3.8kg
175W
  • M18000-48GT-P-ED
4.04kg
95W
  • M18000-24GT20SFP4XS-ED
3.76kg
100W
  • M18000-08XS-ED
3.42kg
85W
  • M18000-08XS-EF
3.52kg
120W
  • M18000-16XS-CB
4.20kg
156W
  • M18000-16XT-CB
4.50kg
250W
  • M18000-40XS-CB
5.20kg
296W
  • M18000-48XS-DC
4.25kg
232W
  • M18000-24XS4QXS-DC
4.0kg
208W
  • M18000-12QXS-DC
3.92kg
200W
  • M18000-24QXS-DB
4.95kg
374W
  • M18000-12CQ-EH
5.4kg
366W
Multiservice Module
  • M18000-MSC-ED
4.58kg
190W
  • M18000-WS-ED
4.58kg
190W
  • RG-WALL 1600-B-ED
4.58kg
190W
RG-N18014
RG-N18012
RG-N18010
RG-N18007
M18014-CM II
M18014-CM
N18014 Control Engine
M18012-CM II
M18012-CM
N18012 Control Engine
M18010-CM II
M18010-CM
N18010 Control Engine
M18007-CM
M18007-CM II
M18007-CM II Lite
2. Power Supply
RG-PA600I
RG-PD600I
RG-PA1600I
RG-PD1600I
RG-PA1600I-PL
RG-PA3000I-PL
3. Fabric Engine
M18014-FE-D III
M18014-FE-D I
M18012-FE-D I
M18010-FE-D III
M18010-FE-D I
M18010-FE-C I
4. Line Card & Service Module
M18000-44SFP4XS-ED
M18000-44SFP4XS-EF
M18000-48GT-ED
M18000-48GT-EF
M18000-48GT-P-ED
M18000-08XS-ED
8 10GE fiber ports (SFP+, LC)
M18000-08XS-EF
M18000-16XT-CB
16 10GE copper ports (RJ45)
M18000-48XS-DC
M18000-24XS4QXS-DC
M18000-12QXS-DC
M18000-24QXS-DB
M18000-12CQ-EH
12 100GE fiber ports(QSFP28)
Multi-service Line Card
RG-WALL 1600-B-ED
M18000-MSC-ED
M18000-WS-ED
5. Transceiver and Cable
XG-SFP-AOC10M
40G Cable for QSFP+, 5M
40G-QSFP-LR4-PSM-SM1310
QSFP-MPO8-4LC-SM-1M
QSFP-MPO8-4LC-MM-1M
FE-SFP-LX-MM1310
FE-SFP-LH15-SM1310
CON-DB9/RJ45-2M
Next-Generation Multi-Process
Modular OS
Rich Data Center Features
VSU Multiple-to-One
VSD One-to-Multiple
TOLLY Group
Supported VSU and VSD
Only One Switch to Manage
Comparison of Port Bandwidths
Frame Size (bytes)
Latency Comparison
64-byte 0.532 0.650
128-byte 0.545 0.651
512-byte 0.588 0.666
1518-byte 0.586 0.665
4096-byte 0.586 0.665
9216-byte 0.586 0.665
Port Buffer Comparison
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
Capacity 3
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
512,000
Capacity 3
170,000
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
128,000
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Entry Comparison
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
Capacity 3
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
512,000
Capacity 3
170,000
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
28,000
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
The test results show that:
Up to 512K MAC entries
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
Capacity 3
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
512,000
Capacity 3
170,000
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
128,000
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Entry Comparison
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
Capacity 3
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
512,000
Capacity 3
170,000
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
28,000
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
control modules switch
Uplink Failure 30ms
Main and Backup
Main switch failure 11ms
Backup switch failure 11ms
Uplink failover: 35 ms
Stability
Tolly Certified Features
OpenFlow 1.3 Main Feature
Stateless Process Restart
Hot Process Patching
N+1 Fabric Module Redundancy
Hot Swappable Fabric Module
Power Consumption Analysis
  Without Any
Line Card
Load All
Modules - 0%
Traffic
Load All
Modules - 30%
Traffic
Load All
Modules - 100%
Traffic
Difference
between 100%
traffic and without
any line card
Average Apparent
Power per line
card with 100%
traffic
Average Apparent
Power per 40GbE
port with 100%
traffic
  Apparent Power
Without Any
Line Card
1.456VA
Load All
Modules - 0%
Traffic
2.573VA
Load All
Modules - 30%
Traffic
2.742VA
Load All
Modules - 100%
Traffic
3.108VA
Difference
between 100%
traffic and without
any line car
1.652VA
Average Apparent
Power per line
card with 100%
traffic
206.5VA
Average Apparent
Power per 40GbE
port with 100%
traffic
8.6VA
TOLLY Group
Frame Size (bytes)
Latency Comparison
64-byte 0.532 0.650
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
Capacity 3
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
512,000
Capacity 3
170,000
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
128,000
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Entry Comparison
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
Capacity 3
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
512,000
Capacity 3
170,000
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
28,000
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
Capacity 3
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
512,000
Capacity 3
170,000
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
128,000
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Entry Comparison
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
Capacity 3
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
512,000
Capacity 3
170,000
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
28,000
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Uplink Failure 30ms
Main and Backup
Stability
  Without Any
Line Card
Load All
Modules - 0%
Traffic
Load All
Modules - 30%
Traffic
Load All
Modules - 100%
Traffic
Difference
between 100%
traffic and without
any line card
Average Apparent
Power per line
card with 100%
traffic
Average Apparent
Power per 40GbE
port with 100%
traffic
  Apparent Power
Without Any
Line Card
1.456VA
Load All
Modules - 0%
Traffic
2.573VA
Load All
Modules - 30%
Traffic
2.742VA
Load All
Modules - 100%
Traffic
3.108VA
Difference
between 100%
traffic and without
any line car
1.652VA
Average Apparent
Power per line
card with 100%
traffic
206.5VA
Average Apparent
Power per 40GbE
port with 100%
traffic
8.6VA
The Ruijie Newton 18000 platform is applicable to a wide range of deployment scenarios. The series can act as the core for large campus network, data center network, integrated network of data center and campus network, and large MAN. Respective illustrations are shown below.
Large Campus Network Core
Large MAN Core
Hardware Installation Guide
Quick Installation Guide
Product Datasheet
Brochure
RGOS Configuration Guide
RGOS Command Reference
White Paper
Test Report
Software Download
Implementation Cookbook
PoC Guide
Case Study
SCN+ Higher Education Solution
High-res Photos
Video
