RG-S6250-48XS8CQ 10GE Data Center Access Switch
  • 48 x 10GE SFP+ ports and 8 x 100GE QSFP28 ports
Thông số chi tiết chính
De-stacking
M-LAG
Tài liệu
RG-S6250-48XS8CQ
48 x 10GE ports and 8 x 100GE ports
Power supply module slots
Fan module slots
One management port, one console port, and one USB port (compliant with the USB2.0 standard)
2.56Tbps
1920 Mpps
4094
RG-S6250-48XS8CQ
(W × D × H)
442 mm × 387 mm × 44 mm (17.40 in. x 15.24 in. x 1.73 in.), 1 RU
8 kg (17.64 lbs., including two power supply modules and four fan modules)
RG-S6250-48XS8CQ
AC
Frequency: 50 Hz to 60 Hz
Rated input current: 3.5 A to 7.2 A
High-Voltage DC (HVDC)
Input voltage range: 192 V DC to 288 V DC
Rated input current: 3.6 A
Low-Voltage DC (LVDC)
Input voltage range: –42 V DC to –72 V DC
Rated input voltage: –48 V DC
Rated input current: 23 A
Maximum Power Consumption
< 300 W
RG-S6250-48XS8CQ
10% to 90% RH (Non-condensing)
Software Specification
RG-S6250-48XS8CQ
L2 Protocols
IEEE802.3ad (Link Aggregation Control Protocol), IEEE802.1p, IEEE802.1Q, IEEE802.1D (STP), IEEE802.1w (RSTP), IEEE802.1s (MSTP), IGMP Snooping, MLD Snooping, Jumbo Frame (9 KB), IEEE802.1ad (QinQ and selective QinQ), and GVRP
L3 Protocols (IPv4)
BGP4, OSPFv2, RIPv1, RIPv2, MBGP, LPM Routing, Policy-based Routing, Routing Policy, ECMP, WCMP, VRRP, IGMP v1/v2/v3, PIM-SSM/SM/DM, MSDP, and Any-RP
Neighbor Discovery, ICMPv6, Path MTU Discovery, DNSv6, DHCPv6, ICMPv6, ICMPv6 redirection, ACLv6, TCP/UDP for IPv6, SNMP v6, Ping/Traceroute v6, IPv6 RADIUS, Telnet/SSH v6, FTP/TFTP v6, NTP v6, IPv6 MIB support for SNMP, VRRP for IPv6, and IPv6 QoS
Static routing, ECMP, PBR, OSPFv3, RIPng, BGP4+, MLD v1/v2, PIM-SMv6, manual tunnel, automatic tunnel, IPv4 over IPv6 tunnel, and ISATAP tunnel
Data Center Features
IPv6 VXLAN over IPv4
PFC and ECN
M-LAG
OpenFlow 1.3
sFlow sampling
802.1p, DSCP, and ToS priority mapping
Priority marking and remarking
Queue scheduling mechanisms, including SP, WRR, DRR, SP+WRR, and SP+DRR
Congestion avoidance mechanisms, including WRED and trail drop
* MPLS VPN
Virtualization
Cache Management
Cache status monitoring and traffic microburst identification
HA Design
GR for RIP/OSPF/BGP, BFD, DLDP, REUP dual-link fast switching, RLDP unidirectional link detection, 1+1 power redundancy, fan redundancy, and hot swapping for all line cards and power supply modules
Security Features
Network Foundation Protection Policy (NFPP), CPU Protection Policy (CPP), DDoS attack defense, unauthorized data packet detection, data encryption, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 authentication for OSPF, RIPv2, and BGPv4 packets, Telnet login and password mechanisms for restricted IP addresses, uRPF, broadcast packet suppression, DHCP Snooping, ARP spoofing prevention, ARP check, and hierarchical user management
Management Modes
SNMP v1/v2/v3, Telnet, Console, MGMT, RMON, SSH v1/v2, FTP/TFTP, NTP, Syslog, SPAN/RSPAN/ERSPAN, Telemetry, ZTP, NETCONF, Python, fan and power supply alarming, and over-temperature alarming
DHCP Client, DHCP Relay, DHCP Server, DNS Client, UDP Relay, ARP Proxy, and Syslog
Take the following steps to configure an RG-S6250-48XS8CQ switch:
● Select the chassis.
● Select the fan and power supply modules.
● Select expansion modules based on service requirements.
● Select optical transceivers based on port requirements.
RG-S6250-48XS8CQ
48 x 10GE ports and 8 x 100GE ports, supporting hot swapping
Two power supply module slots and four fan module slots
Power supply modules: RG-PA550I-F and RG-PD800I-F
Fan module: M1EFAN II-F
RG-PA550I-F
RG-PD800I-F
800 W power supply module (48 V LVDC)
M1EFAN II-F
Fan module, supporting 3+1 redundancy, hot swapping, and front-to-rear airflow
100GE Optical Transceivers
100GE SR optical transceiver, QSFP28 package, MPO connector, 850 nm wavelength, up to 70 m over OM3 optical fibers or 100 m over OM4 optical fibers
100GE LR optical transceiver, QSFP28 package, LC connector, 1310 nm wavelength, up to 10 km over SMF
100GE iLR optical transceiver, QSFP28 package, LC connector, 1310 nm wavelength, up to 2 km over SMF
40GE and 10GE Optical Transceivers
40GE SR optical transceiver, QSFP+ package, MPO connector (used in combination with OM3/OM4 MPO optical fibers, 8-core, 850 nm wavelength), up to 100 m over OM3 optical fibers or 150 m over OM4 optical fibers
40GE SR optical transceiver, QSFP+ package, MPO connector (used in combination with OM3/OM4 MPO optical fibers, 8-core/12-core, 850 nm wavelength), up to 300 m over OM3 optical fibers or 400 m over OM4 optical fibers
40GE LR optical transceiver, QSFP+ package, LC connector (used in combination with LC optical fibers, 2-core, 1310 nm wavelength), up to 10 km over LC optical fibers
10GE SR optical transceiver, SFP+ package, up to 300 m
10GE LR optical transceiver, SFP package, up to 10 km
10GE ER optical transceiver, SFP+ package, up to 40 km
10GE ZR optical transceiver, SFP+ package, up to 80 km
