Thông số chi tiết chính
De-stacking
M-LAG
Tài liệu
RG-S6510-4C
25GE, 40GE, and 100GE ports
 Slots
Expansion Module Slots
Power supply module slots
Fan module slots
6.4 Tbps
2030 Mpps
4094
RG-S6510-4C
(W × D × H)
442 mm × 520 mm × 86 mm
(2 RU)
About 19 kg (including power supply modules and fan modules)
RG-S6510-4C
AC
Rated voltage range: 100 VAC to 240 VAC, 50 Hz to 60 Hz
Maximum voltage range: 90 VAC to 264 VAC, 50 Hz to 60 Hz
High-voltage DC
Input voltage range: 192 VDC to 288 VDC
Input current range: < 4.5 A
Maximum Power Consumption
< 650 W
RG-S6510-4C
0°C to 40°C
10% to 90% RH (Non-condensing)
RG-S6510-4C
L2 Protocols
L3 Protocols (IPv4)
IPv6 Basic Protocols
Data Center Features
IPv6 VXLAN over IPv4
RDMA
M-LAG
OpenFlow 1.3
sFLOW sampling
INT
Virtualization
Virtual Switching Unit
Cache Management
Cache status monitoring and management, and identification of burst traffic
HA Design
Security Features
Management Mode
SNMP v1/v2/v3, Netconf, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP clock, Syslog, SPAN/RSPAN, Telemetry, ZTP, Python, fan and power supply alarm, and temperature alarm
● Select the switch, fan, and power supply modules.
● Select expansionmodules based on port
● Select optical transceivers.
RG-S6510-4C
RG-PA800I-F
M6500-FAN-F
M6500-08CQ
Eight QSFP28 ports
M6500-24VS2CQ
M6500-16QXS
16 QSFP ports
100GE Optical Transceivers
100GE SR optical transceiver, QSFP28 package, MPO connector (850 nm wavelength)
The transmission distance is 100 m when OM4 optical fibers are used.
100GE LR single-mode optical transceiver, QSFP28 package, LC connector (used in combination with LC optical fibers, 2-core, 1310 nm wavelength), maximum transmission distance of 10 km
100GE iLR optical transceiver, QSFP28 package, LC connector (used in combination with LC optical fibers, 2-core, 1310 nm wavelength), maximum transmission distance of 2 km
40GE and 10GE Optical Transceivers
40GE SR optical transceiver, QSFP+ package, MPO connector (used in combination with OM3/OM4 MPO optical fibers, 8-core/12-core, 850 nm wavelength)
The transmission distance is 100 m when OM3 optical fibers are used and 150 m when OM4 optical fibers are used.
40GE LR optical transceivers, QSFP+ package, LC connector (used in combination with LC optical fibers, 2-core, 1310 nm wavelength), maximum transmission distance of 10 km
40GE SR optical transceivers, QSFP+ package, MPO connector (used in combination with OM3/OM4 MPO optical fibers, 8-core/12-core, 850 nm wavelength)
The transmission distance is 300 m when OM3 optical fibers are used and 400 m when OM4 optical fibers are used. The port can be split into four ports to support the 10GE SFP+ transceiver.
25GE Optical Transceivers
VG-SFP-SR-SM850
25GE SR optical transceiver, SFP28 package, LC connector, and 850 nm wavelength
The transmission distance is 100 m when OM4 optical fibers are used and 70 m when OM3 optical fibers are used.
25GE LR optical transceiver, SFP28 package, LC connector, and 1310 nm wavelength
The transmission distance is 10 km when single-mode fibers are used.
