RG-S7808C Thiết bị chuyển mạch - 1
RG-S7808C Thiết bị chuyển mạch - 2
RG-S7808C Thiết bị chuyển mạch - 3
RG-S7808C Thiết bị chuyển mạch - 4
RG-S7808C Thiết bị chuyển mạch - 5
RG-S7808C Thiết bị chuyển mạch - 6
RG-S7808C Thiết bị chuyển mạch - 7
RG-S7808C Thiết bị chuyển mạch - 8
RG-S7808C Thiết bị chuyển mạch - 9
RG-S7808C Thiết bị chuyển mạch - 10
RG-S7808C 10 RU Modular Campus Core Switch
Modular Core Switch RG-S7808C
Compact chassis design with a height of 10 RU improves cabinet space utilization. A single card supports up to 52 non-combo ports, meeting the networking requirements of small and medium-sized core networks or medium-sized network aggregation scenarios.
N+M Power Supply Redundancy
1+1 Fan Module Redundancy
RG-S7805C
RG-S7808C
RG-S7810C
2 x supervisor module slots
3 x line card slots
1 x fan module slot
6 x line card slots
4 x power module slots
Supervisor module
M7805C-CM II
M7808C-CM II
M7810C-CM
M7810C-CM-F
Switch fabric module
line card
● M7800C-32XS4QXS-DA
● M7800C-24GT24SFP4XS-EB
● M7800C-24SFP/12GT4XS-EB
● M7800C-48GT4XS-EB
● M7800C-48SFP4XS-EB
● M7800C-48GT-FA
● M7800C-48SFP-FA
● M7800C-48XS-FB
● M7800C-8CQ-FB
*1
● M7800C-48GT4XS-EB
● M7800C-48GT-FA
● M7800C-48SFP-FA
● M7800C-48XS-FB
● M7800C-8CQ-FB
*1
● M7800C-48GT4XS-EB
● M7800C-48GT-FA
● M7800C-48SFP-FA
● M7800C-48XS-FB
● M7800C-8CQ-FB
*1
RG-PA300I-F
RG-PA460I-F
RG-PA1000I-F
RG-PA600I-F
RG-PA1600I-F
RG-PA600I
RG-PA1600I
M05C-FAN (pre-installed 1)
M08-FAN (pre-installed 2)
M10C-FAN (pre-installed 2)
Module management port
M7805C-CM II:
● 1 x RJ45 console port
● 1 x RJ45 MGMT port
M7808C-CM II:
M7810C-CM:
M7810C-CM-F:
● 1 x RJ45 console port *2
M7810C-CM: 1 x USB 2.0 port
M7810C-CM-F: 1 x USB 2.0 port
RG-S7805C
RG-S7808C
RG-S7810C
4500 Mpps
9000 Mpps
12000 Mpps
System switching capacity *4
6000 Gbps
12000 Gbps
16000 Gbps
Supervisor module:
Line card
Supervisor module:
Line card
Supervisor module:
Line card
M7805C-CM II: supported
M7808C-CM II: supported
M7805C-CM II:8 MB
EB card: 8 MB
DA/FA/FB card: 16 MB
M7808C-CM II: 16 MB
EB card: 8 MB
M7810C-CM/M7810C-CM-F: 16 MB
EB card: 8 MB
M7805C-CM II: 1 GB
EB card: 512 MB
DA/FA/FB card: 8 GB
M7808C-CM II: 8 GB
EB card: 512 MB
DA/FA/FB card: 8 GB
M7810C-CM/M7810C-CM-F: 8 GB
EB card: 512 MB
DA/FA/FB card: 8 GB
M7805C-CM II: 4 GB DDR3
EB card: 1 GB DDR3
DA card: 1 GB DDR4
FA/FB card: 2 GB DDR4
M7808C-CM II: 4 GB DDR4
EB card: 1 GB DDR3
DA card: 1 GB DDR4
EB card: 1 GB DDR3
DA card: 1 GB DDR4
M7810C-FE-D I: 1 GB DDR4
M7810C-FE-F I: 2 GB DDR4
EB: 4 MB
FB: 32 MB
FA: 8 MB
DA: 16 MB
EB: 4 MB
FB: 32 MB
FA: 8 MB
DA: 16 MB
EB: 4 MB
FB: 32 MB
FA: 8 MB
DA: 16 MB
RG-S7805C
RG-S7808C
RG-S7810C
4 x pluggable power modules
RG-PA300I-F (AC input):
RG-PA460I-F (AC input):
RG-PA1000I-F (AC input):
RG-PA600I-F (AC input):
RG-PA1600I-F (AC input):
● Maximum input current: 16 A
RG-PA600I (AC input):
RG-PA1600I (AC input):
RG-PA300I-F: 300 W
RG-PA460I-F: 460 W
RG-PA1000I-F:
● 100 V AC to 176 V AC: 800 W
RG-PA600I-F: 600 W
RG-PA1600I-F:
RG-PA600I: 600 W
RG-PA1600I:
Module power consumption
M05C-FAN: < 80 W
M7805C-CM II: < 21 W
M08-FAN: < 88 W
M7808C-CM II: < 50 W
M10C-FAN: < 216 W
M7810C-CM: < 50 W
M7810C-CM-F: < 110 W
M7800C-32XS4QXS-DA: < 210 W
M7800C-48GT4XS-EB: < 70 W
M7800C-48SFP4XS-EB: < 101 W
M7800C-48GT-FA: < 75 W
M7800C-48SFP-FA: < 95 W
M7800C-48XS-FB: < 160 W
M7800C-8CQ-FB: < 130 W
RG-S7805C
RG-S7808C
RG-S7810C
4 RU
10 RU
10 RU
28.05 kg (61.84 lbs)
43.93 kg (96.85 lbs)
68.30 kg (150.58 lbs)
RG-S7805C
RG-S7808C
RG-S7810C
27°C (80.6°F): 70 dB
Max Noise: 77 dB
Max Noise: 77 dB
Max Noise: 77 dB
Supervisor module redundancy
1+1 redundancy (same model)
N+M redundancy (same model)
Module hot swapping
Over-temperature alarming
Service port: 4 kV
RG-S7805C
RG-S7808C
RG-S7810C
RG-S7805C
RG-S7808C
RG-S7810C-X
3 x line card slots
1 x fan module slot
6 x line card slots
8 x line card slots
Supervisor module
M7805C-CM-X
M7808C-CM-X
M7810C-CM-X
M7810C-FE-X I
M7810C-FE-X II
line card
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-24GT8SFP8XS-XA
M7800C-32XS-XA
M7800C-52XS-XB
M7800C-12CQ-XB
M7800C-48XT-P-XB
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-32XS-XA
M7800C-52XS-XB
M7800C-12CQ-XB
M7800C-48XT-P-XB
M7800C-8SFG-XB
M7800C-8SFX-XB
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-32XS-XA
M7800C-52XS-XB
M7800C-12CQ-XB
M7800C-48XT-P-XB
M7800C-8SFG-XB
M7800C-8SFX-XB
RG-PA300I-F
RG-PA460I-F
RG-PA1000I-F
RG-PA600I-F
RG-PA1600I-F
RG-PA600I
RG-PA1600I
RG-PD600I
M7805C-CM-X:
M7808C-CM-X:
M7810C-CM-X:
M7810C-FE-X I/II:
RG-S7805C
RG-S7808C
RG-S7810C-X
4500 Mpps
9000 Mpps
14300 Mpps
6000 Gbps
12000 Gbps
19200 Gbps
Supervisor module:
Line card:
Supervisor module:
Line card:
Supervisor module:
Line card:
M7805C-CM-X: supported
M7808C-CM-X: supported
M7810C-CM-X: supported
M7805C-CM-X: 16 MB
XA/XB card: 16 MB
M7808C-CM-X: 16 MB
XA/XB card: 16 MB
M7810C-CM-X: 16 MB
M7810C-FE-X I/II: 16 MB
XA/XB card: 16 MB
M7805C-CM-X: 8 GB
XA/XB card: 8 GB
M7808C-CM-X: 8 GB
XA/XB card: 8 GB
M7810C-CM-X: 8 GB
M7810C-FE-X I/II: 8 GB
XA/XB card: 8 GB
M7805C-CM-X: 4 GB DDR4
XA/XB card: 4 GB DDR4
M7808C-CM-X: 4 GB DDR4
M7810C-CM-X: 4 GB DDR4
M7810C-FE-X I: 1 GB DDR4
M7810C-FE-X II: 4 GB DDR4
XB series line card: 35 MB
M7800C-32XS-XA: 35 MB
RG-S7805C
RG-S7808C
RG-S7810C-X
RG-PD600I (DC input):
● Maximum input current: 20 A
RG-PA300I-F: 300 W
RG-PA460I-F: 460 W
RG-PA1000I-F:
RG-PA600I-F: 600 W
RG-PA1600I-F:
RG-PA600I: 600 W
RG-PA1600I:
RG-PD600I: 600 W
M05C-FAN: < 80 W
M7805C-CM-X: < 40 W
M08-FAN: < 88 W
M7808C-CM-X: < 62 W
M7800C-8SFG-XB: < 250 W
M7800C-8SFX-XB: < 250 W
M10C-FAN: < 216 W
M7810C-CM-X: < 60 W
M7810C-FE-X I: < 50 W
M7810C-FE-X II: < 160 W
M7800C-48GT4XS-XA: < 85 W
M7800C-48SFP4XS-XA: < 117 W
M7800C-24GT8SFP8XS-XA: < 95 W
M7800C-32XS-XA: < 149 W
M7800C-52XS-XB: < 250 W
M7800C-12CQ-XB: < 240 W
M7800C-48XT-P-XB: < 300 W
M78-PSE-X
2 x PoE out ports
RG-PA1600I-PL
RG-PA1600I-PL (AC input):
RG-PA1600I-PL
5.0 kg (11.02 lbs)
RG-S7805C
RG-S7808C
RG-S7810C-X
4 RU
10 RU
10 RU
RG-S7805C
RG-S7808C
RG-S7810C-X
Max Noise: 77 dB
Max Noise: 77 dB
Max Noise: 77 dB
Module hot swapping
Over-temperature warning
Service port: 4 kV
RG-S7805C
RG-S7808C
RG-S7810C-X
RG-S7800C Series
IPv4/IPv6 IS-IS
EVPN
Policy-based routing (PBR)
IPv4 and IPv6 ECMP
IGMP snooping v1/v2/v3
MLD v1/v2 snooping
MPLS IPv6
MPLS 6VPE
Port-based rate limiting
802.1p
CAR
VRRP for the super-VLAN
SPAN, RSPAN, and ERSPAN
FTP, TFTP, and Xmodem
Web-based NMS
RG-S7800C-X Series
protocol-based VLAN
Super-VLAN
STP (IEEE 802.1.d)
RSTP (IEEE 802.1w)
MSTP (IEEE 802.1s)
OpenFlow 1.3
DHCPv6 client
DHCPv6 relay
FTP Server
FTP Client
NTP server
NTP Client
SNTP Client
TFTP Client
TFTP Server
BGP4
BGP4+
IS-ISv4
IS-ISv6
OSPFv3
RIP
RIPng
Routing Policy
PIM-DM
PIM-SM
MLD v1/v2 snooping
MPLS 6VPE
MPLS IPv6
MPLS forwarding
LDP
LSP
VXLAN Layer 2 bridge
VXLAN Layer 3 gateway
Standard IP ACL
extended IP ACL
extended MAC ACL
Layer 2 and Layer 3 port ACL
VLAN ACL
Expert-level ACL
ACL COUNTER
ACL LOGGING
ACL REMARK
802.1P
SP
WRR
SP+WFR
RED/WRED
MPLS QOS
VRRP+
Faulty optical port isolation
port security
RADIUS
SSHv2
IPv6 SAVI
SNMP V1/V2c/V3
RMON
GRPC
SPAN
ERSPAN
VLAN mirroring
Web-based NMS
Energy-Saving Design
Switch Chassis
RG-S7805C
RG-S7808C
RG-S7810C
RG-S7810C-X
Supervisor Modules
M7805C-CM II
M7808C-CM II
M7810C-CM
M7810C-CM-F
M7805C-CM-X
M7808C-CM-X
M7810C-CM-X
Notes:
Switch Fabric Modules
M7810C-FE-D I
M7810C-FE-F I
M7810C-FE-X I
M7810C-FE-X II
M7800C-32XS4QXS-DA
M7800C-48GT4XS-EB
M7800C-48SFP4XS-EB
M7800C-48GT-FA
M7800C-48SFP-FA
M7800C-48XS-FB
48 x 1GE/10GE SFP+ ports (LC)
M7800C-8CQ-FB
Notes:
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-32XS-XA
M7800C-52XS-XB
52 x 1GE/10GE SFP+ ports (LC)
M7800C-12CQ-XB
M7800C-48XT-P-XB
M7800C-8SFG-XB
M7800C-8SFX-XB
Power Chassis and Modules
RG-PA300I-F
RG-PA460I-F
RG-PA600I
RG-PA600I-F
RG-PA1000I-F
RG-PA1600I
RG-PA1600I-F
M78-PSE-X
RG-PA1600I-PL
RG-PD600I
CWDM Transceiver
SFG-LR-SM
SFX-LR-SM
